Is there a way to call 3D convex hull from C# code?
Basically I want to get the mesh from a set of points to analyse volume and sections. Any ideas how to call this or if there is component that I can reference?
Hi @ankere
You can use Quickhull from Dale’s Polyhedra plug-in as shown here
Thanks @DanielPiker, that helped a lot.
In the end I used this code:
and found the component name from here:
 var com = rd.Components.FindComponent("Meshedit2000_3DConvexHull");
    object[] args = new object[] {x};
    string[] warnings;
    if (com != null)
      var results = com.Evaluate(args, false, out warnings);
      A = results[0];
You could also implement MIConvexHull directly, which is what MeshEdit implements I believe. Here’s a GHPython example, should be simple to port to C#:
Thanks, I was looking into that and even cloned the repo from github but for now I’ll stick with the fastest solution until I have time to properly do it.
