I’m having some trouble updating VA Plans and Sections - if I select all 7 in my model, the progress bar stalls at 9%. If I just chose one section to update, it stalls at 50%. Rhino is still using one core of the processor, but whatever its doing is taking forever.
Should I just re-make the sections and plans, or is there a fix / workaround please?
The file is quite large, 250 MB, and I’ve used a lot of groups, plus a lot of VRay materials, and its all Rhino objects, no VisARQ objects. The Levels dialogue is not showing (but I used it for this model). They worked fine in the model about a month ago, I’ve made a few geometry and material changes but cant see what the problem is.
Hi Jonnie,
Can you send the file to visualarq@asuni.com? We will check it out and try to figure out what’s causing this problem. If you created the plan/section view once, you should be able to update it with no problem.
Thanks,
