Hi everyone,
I am trying to bridge two separate parts (created from a SubD Variable Offset converted via Mesh Brep) using Loft (also converted to Mesh), join them together, and then smoothly round/fillet the edges using Quad Remesh and SubD from Mesh.
However, Quad Remesh seems to disconnect or split the edges along the seams instead of welding and smoothing them into a single continuous surface (see attached screenshot).
Files:
SubD_variable_offset_join_issue.3dm (194.5 KB)
Variable_offset_join_issue.gh (14.6 KB)
My current workflow:
- Base parts from SubD Variable Offset → Mesh Brep
- Bridge the gap with Loft → converted to Mesh
- Mesh Join (flattened)
- Weld Mesh
- Quad Remesh → SubD from Mesh
What am I missing to keep the seams welded and get smooth, rounded transitions across the bridged edges? Should I use Align Vertices or ShrinkWrap before Quad Remesh, or adjust specific Quad Remesh settings?
Also, as a bigger question: is it possible to achieve this entire workflow cleanly using pure Breps / Surfaces instead?
Thanks in advance for any tips!
