Every time I reopen GH, Value Set Picker resets and messes up upstream components (ElementType.ByName, etc.) Frankly, this is very annoying, I need to fix my definition every time.
I was testing it here and both the Filter and the selection are sticking through a save.
But it may matter what is upstream. What component is inputting into the picker? I am not sure what happens if the list is not available the first time it runs on open?
Also, there was a new installer a couple days ago, have you installed the newer version?
Trying to bring this topic again, installed the latest V0.7
Issue: Value picker resets after reopening. I’m running a simple rhino file with 4 walls only.
Close the GH Definition, and Re-open
Lost my Picker’s selection
Hi @tay.othman,
There is a quick fix on version 0.8, do you mind testing it?
To install it you should change the update channel to ‘Daily’ from the Rhino.Inside Options dialog.
Hello @kike
The problem is still there after installing 0.8.7838.9222 daily build.
I’ll wait for another daily build to test it, also I don’t mind staying on the daily builds since the excercise I’m doing is not that critical.
Thank you
Tay
Thanks for confirming, it helps.
This is still an issue with Rhino 8 Grasshopper 1.0.0008
