andheum
(Andrew Heumann)
March 12, 2020, 11:08am
6
There is a technique called “decoupling” that uses metahopper but it is somewhat more advanced/involved. If you feel like trying it there are some example snippets on food4rhino.
I have reviewed the file you sent, and reproduced the issue in question (this in itself was not easy!). I am fairly sure the problem is with either your script or with Grasshopper itself - there have been prior reports of scripting components in GH with slow/long running functions failing to return control of mouse events back to the canvas. I do not think this issue in general is something I can solve.
However, I can recommend a workaround. In my preliminary tests this approach below eliminate…
