Why does a Value List node not automatically update when you plug it into most other commands? For example, if I plug a Value List (which by default holds “One, Two, Three, Four” as options, not automatically update to “1, 2, 3” (no 4, neither Four) if I plug it into the Curvature slot C of a Blend Curve node?
There seem to be a few commands (such as Weight within Peacock) that autofill the Value List, but not most commands. The fact that you need to manually fill a Value List nearly each time you use it makes that node less useful than it could be (unless I’m using it the wrong way!)
Matt
