mgraham
(Mgraham)
March 4, 2020, 9:13pm
1
I put this test in my code:
ON_EarthAnchorPoint earthPoint = doc.Properties().EarthAnchorPoint();
if (earthPoint.EarthCoordinateSystem() != ON::EarthCoordinateSystem::Unset)
ON_3dVector northVec = earthPoint.ModelNorth();
double lat = earthPoint.Latitude();
// and other code like this
but it always evaluates as earthPoint.EarthCoordinateSystem() == ON::EarthCoordinateSystem::Unset even when I have set an EarthAnchorPoint in Rhino.
If I simply retrieve the values, I do get back the values I set, but I don’t want garbage values if the EarthAnchorPoint has not been set. Is there another way to tell if my values are valid?
dale
(Dale Fugier)
March 4, 2020, 10:12pm
2
Hi @mgraham ,
The EarthAnchorPoint command does not set this value. So you’ll need to do so programatically.
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
const double latitude_degrees = 47.620397;
const double longitude_degrees = -122.349179;
const double ground_elevation_feet = 207.0;
const double observation_deck_height_feet = 520.0;
ON_EarthAnchorPoint eap;
eap.SetEarthLocation(
ON::EarthCoordinateSystem::MeanSeaLevel,
ON::LengthUnitSystem::Feet,
latitude_degrees,
longitude_degrees,
ground_elevation_feet + observation_deck_height_feet
eap.m_name = L"Space Needle";
eap.m_description = L"Space Needle, Seattle, Washington USA";
eap.m_url = L"https://www.spaceneedle.com/";
context.m_doc.Properties().SetEarthAnchorPoint(eap);
return CRhinoCommand::success;
Use ON_EarthAnchorPoint::EarthLocationIsSet().
static bool PrintEarthAnchorPoint(CRhinoDoc& doc)
const ON_EarthAnchorPoint& eap = doc.Properties().EarthAnchorPoint();
bool rc = eap.EarthLocationIsSet();
if (rc)
const ON_3dmUnitsAndTolerances& doc_units = doc.Properties().ModelUnitsAndTolerances();
ON_3dmUnitsAndTolerances meters_units;
meters_units.m_unit_system.SetUnitSystem(ON::LengthUnitSystem::Meters);
ON_wString sLatitudeDMS, sLatitudeDeg;
ON_wString sLongitudeDMS, sLongitudeDeg;
ON_wString sElevation;
double earth_latitude = eap.Latitude(0.0);
double earth_longitude = eap.Longitude(0.0);
double earth_elevation = eap.ElevationInMeters();
RhinoFormatDegreesLatitude(earth_latitude, sLatitudeDMS, 0);
RhinoFormatDegreesLongitude(earth_longitude, sLongitudeDMS, 0);
RhinoFormatDegreesLatitude(earth_latitude, sLatitudeDeg, 1);
RhinoFormatDegreesLongitude(earth_longitude, sLongitudeDeg, 1);
RhinoFormatNumber(earth_elevation, meters_units, doc_units, sElevation, true);
if (floor(earth_latitude) == earth_latitude)
RhinoApp().Print(L"Latitude: %s\n", sLatitudeDMS.Array());
else
RhinoApp().Print(L"Latitude: %s (%s)\n", sLatitudeDMS.Array(), sLatitudeDeg.Array());
if (floor(earth_longitude) == earth_longitude)
RhinoApp().Print(L"Longitude: %s\n", sLongitudeDMS.Array());
else
RhinoApp().Print(L"Longitude: %s (%s)\n", sLongitudeDMS.Array(), sLongitudeDeg.Array());
RhinoApp().Print(L"Elevation: %s\n", sElevation.Array());
return rc;
space-needle.zip (1.2 MB)
– Dale
