EarthAnchorPoint not set in Rhino 8.8
Hello :wave:,
In Rhino 8.8 it appears that the EarthAnchorPoint command does not remember the Lat, Long, Elevation data when set and then queried.
Is this happening to anyone else?
Hi Bob -
That appears to be working fine here.
Sorry, I didn’t add any context to this. :man_facepalming: I’m trying to set it via RhinoCommon API using python3:
#! python3
import Rhino
import scriptcontext as sc
origin = Rhino.Geometry.Point3d(0.0,0.0,0.0)
north = Rhino.Geometry.Plane.WorldXY.YAxis
east = Rhino.Geometry.Plane.WorldXY.XAxis
sc.doc.EarthAnchorPoint.EarthBasepointLatitude = 47.65111166930954
sc.doc.EarthAnchorPoint.EarthBasepointLongitude = -122.35530803623594
sc.doc.EarthAnchorPoint.ModelBasepoint = origin
sc.doc.EarthAnchorPoint.ModelNorth = north
sc.doc.EarthAnchorPoint.ModelEast = east
earthpoint = sc.doc.EarthAnchorPoint
Hi Bob - try
import Rhino
earthpoint.EarthBasepointLatitude = 47.65111166930954
earthpoint.EarthBasepointLongitude = -122.35530803623594
earthpoint.ModelBasepoint = origin
earthpoint.ModelNorth = north
earthpoint.ModelEast = east
sc.doc.EarthAnchorPoint = earthpoint
Does that do what you need?
Sorry for the late reply and thanks for that @pascal :grinning: The issue i’m still seeing after I run that code is that the EarthAnchorPoint cannot be reset. You can see what I mean in the video I’ve attached where I try:
  1. Set the Earth Anchor Point via the API.
  2. Try changing it via EarthAnchorPoint command.
  3. Try changing it again via the API.
This is Rhino SR 8.8
Hi Bob - I cannot reproduce that here - it all just works as far as I can see - can you please run SystemInfo in Rhino and copy/paste the results here?
Sure here’s my info:
Rhino 8 SR8 2024-5-28 (Rhino 8, 8.8.24149.15001, Git hash:master @ 49367284ece6544c4e32d4d2fce81c37a1bd9dff)
License type: Commercial, build 2024-05-28
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.13
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-13-2023 (M-D-Y).
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA Quadro T2000 (NVidia) Memory: 4GB, Driver date: 6-1-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 555.99
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2024
Driver Version: 32.0.15.5599
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.3.2.0
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino8.rhp “ClimateStudioRhino8” 2.0.8868.25570
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 0.0.24138.1238
C:\Users\bfrederick\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.175\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.175.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.46.0\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.46.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24149.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24149.15001
Hi Bob - I would try starting Rhino in Safe Mode - don’t let any of those third party plug-ins load, if asked, then test. Or disable all the ones that do not ship with Rhino in Options > PLug-ins page, then close and restart Rhino. Any different?
I tried that and the behavior is that the EarthAnchorPoint isn’t set when the API is used. I’ll try a re-install and see if anything changes. Thanks for the assistance.
I see… @eirannejad - do you have an idea what might be going on here? This code
import Rhino
Seems to set the EarthAnchorPoint but somehow blocks any further adjustment, for this user, of the EarthAnchorPoint. I cannot repeat.
I see that is on 8.8 and I am on 8.9, I will check 8.8
Hi @bfrederick,
ModelBasepoint needs to read ModelBasePoint .
import Rhino
earthpoint.ModelBasePoint = origin
– Dale
Wow glad that was a simple one!
I got a bit confused with the properties on EarthAnchorPoint since the case is different for EarthBasepointLatitude etc.
Thanks so much for catching that little oversight @dale and others.
