V8 UI BUG: The list of layers is leaving the screen
The list of the layers in the Object preferences is leaving the screen, when there is a lot of layers (basicly any of my bigger project). In V5 there was an arrow for expansion and the layer selection menu looked much better. @Gijs, could you please look at it?
V8 (bug):
V5 (correct behavior):
thanks @morris for reporting
RH-83378 Layer popup in properties panel goes off screen
RH-83378 is fixed in Rhino 8 Service Release 14
Visually it’s still quite a regression compared to V5, but at least it is functional now, thank you. I especially hate the way how the menu don’t respect the position of the cursor and current layer of the object. It’s a bit confusing, if you have a lot of layers. Maybe it can be fixed in the future?
V 5:
V 8.14:
Hi @brian , it doesn’t work. It’s impossible to scroll through the menu. Please see the attached video:
@morris I tested on a fairly large file, and don’t see that behavior you are getting. Can you send me your _SystemInfo, and if possible the file (no need for geometry I guess, just the layer structure)
Hi @Gijs, here is the Systeminfo and the file with layers without geometry (there is just a box to select and test the behavior)
Systeminfo
Rhino 8 SR14 2024-11-12 (Rhino 8, 8.14.24317.14002, Git hash:master @ 69ab12ed53cf1e6d17f23ab5fec3c3f7216df72d)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Apple macOS Version 12.7.5 (Build 21H1222) (Physical RAM: 32GB)
Mac Model Identifier: MacBookPro16,1
Language: en-CZ (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5300M (4 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
GPU Vendor: AMD
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/morris/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libSubstanceImporter.dylib
/Users/morris/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_ogl3_blend.9.dylib
/Users/morris/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/libsubstance_linker.9.dylib
/Users/morris/Library/Application Support/McNeel/Rhinoceros/packages/8.0/SubstanceImporter/2.0.7/SubstanceImporter.rhp “SubstanceImporter” 2.0.7.0
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.14.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.14.24317.14002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.14.24317.14002
layers.3dm (6.4 MB)
Hi Morris -
I was able to reproduce the issue when running on macOS 12.
→ RH-84855 Properties: Can’t Scroll Layer List
From the Apple website, it looks like your machine is compatible with macOS 15. Is there something specific holding you back?
Updating OS isn’t an option for me. I need to run legacy software, like Rhino V5, which I’m stlil using for half of my projects. It’s way more stable and predictable…
