It seems. like that the latest V8 fixed many issue of TestMetal
For me V8 WIP was really unusable inTM since the viewport continued to go BLACK and nothing worked other than closing and reopening Rhino itself.
I’ll try to test this build on my MBP M1Pro too to check as well.
This is the SysInfo from my Mini M1:
Rhino 8 SR0 2022-7-12 (Rhino WIP, 8.0.22193.04306, Git hash:master @ 8bc4867b8fc84e25cfeeb02614e5caa92db40a2a)
License type: Commercial, build 2022-07-12
License details: Cloud Zoo
Expires on: 2022-08-26
Apple macOS Version 12.4 (Build 21F79) (Physical RAM: 16Gb)
Mac Model Identifier: Macmini9,1
Language: en
Apple M1 (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M1
Displays: Unknown (217dpi 2x), Unknown (108dpi 1x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
MateView (2560 x 1707 @ 60.00Hz)
Q27P1B (2560 x 1440 @ 60.00Hz)
USB devices
Dialog Semiconductor (UK) Ltd: MateView
HUAWEI: MateView Combo HID
Razer: Razer DeathAdder Elite
Western Digital: My Passport 071D
EPSON: WF-7720 Series
3Dconnexion: SpaceMouse Compact
Hauppauge: Nova-T Stick
Logitech: USB Receiver
APC: Back-UPS ES 700G FW:871.O2 .I USB FW:O2
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/import_modelio_macos.rhp "Model IO Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp "MPlane" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp "GTS Triangle Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp "VRML/X3D Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp "MeshFromPoints" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp "STL Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp "import_3MF" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp "export_xaml" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp "Cult3D Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp "PDFReader" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp "Import_OBJ" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp "XGL Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp "IGES Import Plug-in" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp "MicroStation file import: import_DGN" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp "Parasolid Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp "RhinoRoslyn" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp "Rhino Bonus Tools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp "Constraints" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp "Constraints UI" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp "Comma Separated Value Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp "Import_FBX" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp "SLC Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp "Export_FBX" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp "Adobe Illustrator Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp "VDA Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp "Points Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp "SLC Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp "Points Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp "Raw Triangles Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp "WAMIT import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp "3D Studio Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp "X Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp "VDA Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp "AnimationTools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp "SketchUp Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp "STL Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp "export_OBJ" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp "Moray Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp "WAMIT Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp "Import_AMF" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp "SolidTools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp "SketchUp Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp "RhinoCPython" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp "POV-Ray Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp "Lightwave Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp "CreaseAngle" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp "AutoCAD file import: import_ACAD" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp "Import_SVG" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp "VRML Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp "OFF Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp "BlockEdit" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp "Rhino Labs Tools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp "X Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp "IGES Export Plug-in" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp "AutoCAD file export : export_ACAD" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp "Squish" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp "Named Position" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp "Renderman Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp "Solidworks Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp "Export_AMF" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp "RAW Triangle Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp "PLY - Polygon File Format Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp "Import_DST" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/import_E57.rhp "E57 Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp "STEP Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp "Lightwave Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp "export_3MF" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp "Export_DAE" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp "STEP Import" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp "ACIS Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp "PLY - Polygon File Format Export" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp "GTS Export" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp "Legacy Rhino Render" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp "QuadRemesh" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp "MeshTools" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 8.0.22193.4306
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp "Import_M" 8.0.22193.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp "Export SVG" 8.0.22193.4306
