Rhino 8 SR0 2022-9-6 instability issues
latest WIP (Rhino WIP, 8.0.22249.12306, Git hash:master @ 40d87b6e847c6c827f8fc10401ce04883ecdfa80) for me is totally unstable.
Till now have experienced:
Crashes as soon as switching from wireframe to ghosted, (really small file) (TestMetal on. Not crashing with testmetal OFF)
Crashes soon after opening a file used to be able to open on previous build (TestMetal on. Not crashing with testmetal OFF)
Sent crash reports
I see your 2 crash reports.
Your SystemInfo did not get sent with them.
Please run SystemInfo in the WIP and post the results here>>
Thanks
Rhino 8 SR0 2022-9-6 (Rhino WIP, 8.0.22249.12306, Git hash:master @ 40d87b6e847c6c827f8fc10401ce04883ecdfa80)
License type: Commercial, build 2022-09-06
License details: Cloud Zoo
Expires on: 2022-10-21
Apple macOS Version 12.5.1 (Build 21G83) (Physical RAM: 16Gb)
Mac Model Identifier: Macmini9,1
Language: en
Apple M1 (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Vendor Name: Apple
  Render version: 4.1
  Shading Language: 4.10
  Z-Buffer depth: n/a
  Total Video Memory: 10922 MB
  Graphics: Apple M1
  Displays: Unknown (217dpi 2x), Unknown (108dpi 1x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
  Apple M1
    MateView (2560 x 1707 @ 30.00Hz)
    Q27P1B (2560 x 1440 @ 60.00Hz)
USB devices
  Dialog Semiconductor (UK) Ltd: MateView
  HUAWEI: MateView Combo HID
  Razer: Razer DeathAdder Elite
  Western Digital: My Passport 071D
  EPSON: WF-7720 Series
  3Dconnexion: SpaceMouse Compact
  Hauppauge: Nova-T Stick
  Logitech: USB Receiver
  APC: Back-UPS ES 700G FW:871.O2 .I USB FW:O2
Bluetooth devices
  None
Third party kernel extensions
  None
Third party plugins
  /Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
  /usr/lib/swift/libswiftAppKit.dylib
  /usr/lib/swift/libswiftCoreData.dylib
  /usr/lib/swift/libswiftFoundation.dylib
  /usr/lib/swift/libswiftCloudKit.dylib
  /usr/lib/swift/libswiftContacts.dylib
  /usr/lib/swift/libswiftCoreML.dylib
  /usr/lib/swift/libswiftVision.dylib
  /usr/lib/swift/libswiftNetwork.dylib
  /usr/lib/swift/libswiftFileProvider.dylib
  /usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
  /usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp	"RhinoCycles"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp	"Snapshots"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp	"RhinoRoslyn"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp	"Rhino Bonus Tools"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/PlugIns/Constraints.rhp	"Constraints"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConstraintsUI.rhp	"Constraints UI"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp	"Grasshopper"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp	"PanelingTools"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp	"AnimationTools"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp	"Commands"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework	"Renderer Development Kit"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp	"RhinoCPython"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp	"RDK_EtoUI"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp	"Displacement"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp	"Rhino Render"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp	"IronPython"	8.0.22249.12306
  /Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp	"Legacy Rhino Render"	8.0.22249.1002
  /Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp	"RhinoCodePlugin"	8.0.22249.12306
Thanks for that information.
I see that you are running two displays with different DPI.
Does Rhino still crash when you disconnect one display?
Tried disconnecting secondary monitor on HDMI, it’s still crashing.
cannot post from here since I get a 4000 char limit.
I’ve sent another crash log from Rhino crash reporter
Language: en
OpenGL Settings
  Safe mode: Off
  Anti-alias mode: 4x
  Vendor Name: Apple
  Render version: 4.1
  Z-Buffer depth: n/a
  Graphics: Apple M1
Graphics processors
  Apple M1
    MateView (2560 x 1707 @ 60.00Hz)
USB devices
Bluetooth devices
  None
  None
Third party plugins
I’ve asked the developers to take a look at your Rhino Crash Reporter submitted reports.
Hopefully one will come up for air soon.
@marco.curato
The developer thinks this specific problem was fixed internally about a week ago. Because of other issues, there has not been a public WIP build released with this fix in it. Because we aren’t sure when the next WIP build will be released, the suggestion is to roll back to the previous WIP that did not have this problem.
Do you still have that DMG?
If not I’ll see if I can find a link to it.
No DMG since I’ve performed updates from within Rhino updater
Message with link sent.
Could you also send me a roll back link?
@GUO
Are you running the Mac WIP and have the same problem?
A new WIP with this specific fix and others will be going out soon, probably tomorrow.
Let’s hold off for now.
I do have the same problem. And it would be great if there’s a fix. :grinning:
The new WIP was rolled out at 7pm PDT yesterday evening.
It has this fix in it.
Please give it a go and let us know if the problem is gone for you.
Thanks
No more crashing BUT:
once TestMetal is turned on after few panning/zooming/rolling the viewport goes blank as in the past builds
Please create a new Topic with an accurate title for this new problem instead of piggybackinjg.
Thanks
