Hi All.
Found an issue on subject. Maybe it’s already known.
Block list is empty after block edit. After selection of any block the list is back.
Hi All.
Hi -
I’m not seeing that here.
Could you please provide your SystemInfo data?
Sure.
Rhino 8 SR0 2023-4-18 (Rhino WIP, 8.0.23108.14305, Git hash:master @ be7db2f4e3d7f64e6403bf46a8f308c540e8e2f5)
License type: Commercial, build 2023-04-18
License details: Stand-Alone
Expires on: 2023-06-02
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 11-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.27
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-23-2022
Driver Version: 31.0.15.2727
Z-Buffer depth: 24 bits
Total Video Memory: 16 GB
C:\Program Files\Rhino 6\Plug-ins\DATAKIT\Rhino6_Import_x64.rhp “Datakit_to_rhino6”
C:\Program Files\SimLab\Plugins\SimLab PDF From Rhino\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Users\Andrey\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Iris\0.7.1\Iris.V7.rhp “Iris” 1.0.0.0
C:\Program Files\Rhino 8 WIP\Plug-ins\Commands.rhp “Commands” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 8 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\RhinoCode\RhinoCPython.rhp “RhinoCPython” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 8 WIP\Plug-ins\BlockEdit.rhp “BlockEdit” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 8 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 8.0.23108.14305
C:\Program Files\Rhino 8 WIP\Plug-ins\SectionTools.rhp “SectionTools”
If you start from empty file, add geometry and create a block with “+” on the panel, then this new block behaves as I described.
If close Block manager and open it again while have blocks in session - no list dropping.
