V6 Raytraced Display Mode -- File Capture or Copy Problem When Saved
I suspect this may already be a known problem. Using the latest WIP.
When using Raytraced Display mode and either capturing to file or clipboard, it renders fine on screen but the saved file isn’t correct. Attached is the result.
jvm
Hi Jim - yeah, I’ve seen similar and logged a bug - thanks. But don’t let that stop you - report 'em if you see 'em, please… we don’t catch them all by a long shot.
I think this is the same: https://mcneel.myjetbrains.com/youtrack/issue/RH-39158
