Firstly, is Serengeti still the best place to post V6 questions?
I just installed V6 last night (upgrade from V5). I did get the notification that I have several plugins that might be compatible, but I didn’t install any (yet).
When I start V6, all viewports are black. I seem to be able to make geomety - it isn’t frozen - but I can’t see anything. PluginManager shows no plugins incompatible with V6.
I’m using an GeForce card (will update this post with # when I get home).
Strangely, when I entered the OpenGL panel in Options, and clicked the down arrow beside Antialiasing, the black/unresponsive viewports went normal and the problem appears to have fixed itself even though I didn’t change anything. I’ll take it!
However, Rhino is using the laptop’s integrated video card. I’ve set it to use the GeForce in the NVIDIA control panel but it still uses integrated. Do I need to toggle something inside Rhino?
Vendor Name: Intel
Render version: 3.0
Shading Language: 1.30 - Intel Build 8.15.10.2342
Driver Date: NA
Driver Version: NA
Maximum Texture size: 4096 x 4096
Z-Buffer depth: 24 bits
Maximum Viewport size: 4096 x 4096
Total Video Memory: n/a
Semi-fixed - I actually had to rollback my driver. However, now I get a crash if I attempt to use raytracing. Also, geometry is invisible until/unless I toggle viewport display mode (wireframe to shaded, etc)
Render version: 4.2
Shading Language: 4.20 NVIDIA via Cg compiler
Driver Date: NA
Driver Version: NA
Total Video Memory: 2096960 KB
Thanks, Nathan. Setting to CPU allows raytracing. A bit more info:
I downloaded a driver update from Dell (instead of nvidia) and now Rhino uses the nvidia card. However, I still see nothing in wireframe mode. Also, edges don’t show in shaded mode despite view settings being set properly.
This might be the motivation I needed to get a new laptop.
