Normally I have my layer panel set up like this:
I have the “Name” column moved to the right as the last column, as names are variable length and I prefer to have the all the other layer controls on the left of that… Plus most of the layer print/material settings are turned off, as I don’t need them generally.
Now, when I use Open and open an ACAD DWG that has a layout page, it resets the column order and turns ALL the columns on…
I hope this is a bug and not intentional behavoir…
Can provide the dwg to test if need be.
Edit: oh, and btw, using Import doesn’t work at all, nothing is imported (the DWG is all in layout space)
Thx, --Mitch
