Hi is there a time-line for V6 to be updated to import SolidWorks 2018?
Thanks,
Eric
Thanks,
Eric
Hi Eric - I think that is in the works - not that that answers your question very wellā¦
(@lowell, am I correct about that?)
I think so. @tim did the update
Great, thanks for that.
Eric
Hi Eric,
Yes, it is in the works (both Windows and Mac platforms). I have it all hooked up at this point (on Windows) but I get repeated crashes opening some files. I have inquired with the company that develops the library we use but have not yet had a chance to implement their suggestion. It will not be included in V6 until I can get the crashing problem resolved.
Cheers,
Tim
@tim any updates here? Iāve received several requests from users on this subject-
Hi @theoutside,
The DataKit people have not fixed the crash yet, Iāve sent them some files. However, in the midst of trying to figure it all out I determined that the crash only occurs in debug builds on Windows. Even more interesting is I tried to see what was different with previous library and found it had the same crash. So, I asked Lowell about it and we decided it was OK to go ahead and merge it in. See https://mcneel.myjetbrains.com/youtrack/issue/RH-43442 for details.
Tim
@theoutside - 6.2 builds open SW 2018 parts.
Thanks Tim.
The other recurrent issue with SW import is that it seemingly randomly ignores the color of SW bodies and parts. Not too surprising considering how complicated applying appearance is in SW; it can be applied at face, body, part and assembly level. But it was better for a while back with the 2016 version it seems like.
Eric
HI Eric,
You can send in a simple file (the simpler the better) that demonstrates the errant behavior. All Iāve done to the plugin recently is hook up the new library. How long ago was it ābetterā? I can look through the change logs and see if I can pinpoint some change (of our own) that might account for it. If it was a change in the library we use it will be complicated. Now that I think about it, it would be handy if the file you send I can pass along to them in the event I need to.
Tim
Hi Pascal, any idea when 6.2 build will be available?
Thanks,
Eric
Hi Eric - it is the current release candidate, so you can get it by setting you updates (Options > Updates and statistics) to look for āService Release candidatesā.
