V5 lists .sldprt files in the open/import dialogue box, but never works. Can anyone confirm if V6 handles them better?
Hi Declan - we’re often, inevitably, somewhat behind the current SW format - probably what you’re running into is that you’re opening a SW file from a later format than is supported. I believe V6 handles SW 2017 files currently. If you think it’s something different, shout, or send me an example…
thanks.
Ah, interesting. It doesn’t look like there’s any way to ‘version down’ during SW export, so this will be an on-going thing. We’re trying to convince our IT dept. to let us install a v6 Beta and SW compatibility would be a big sell.
Right - this makes the whole system extra fragile…
Hello everybody,
is there any option to get the whole structure/scene tree of a .sldprt in rhino? The import works fine for me, but there’s only one layer in rhino but I need the complete structure und don’t want to sort it manually.
Thanks in advance!
Hello - if the import is bringing a nested block, (usually a sldasm, not a sldprt I’d think) and you want all the parts separated out, you can try the attached plug-in to separate all the parts out onto layers-
ExplodeBlocksToLayers.rhp (14.5 KB)
Drag and drop to load it, and run the command ExplodeBlocksToLayers
. My guess is you probably want the non-default command line option to put each part on its own layer.
If that is not it, please describe what you want to do with the sldprt…
Hey, thanks for your fast response.
Yes, I assume the CAD Data has in Solid Works a logical scene tree. Layer A Object A, Layer B Object B, Layer Screws contains all the Screws and so on.
Unfortunately Rhino merges the Geometry at one, the default layer, but I want the structure of Solid Works 1:1 in the Rhino Layer-Manager.
I tried your script but nothing happend - perhaps because I’ve only .sldprt-files at the moment.
Hi Pascal,
I tried your plugin and it just merged all of the geometry from the block into single layer.
update: tried it with ‘NewLayerPerBlock’ option and it works fine.
Hi Igor - use the command line option to control this behavior. You probably want each part on its own layer, that is not the default option. Any better?
yes. Just tried, it works ! thanks
