I have a short question to which I haven´t found an answer to yet:
With the MoveUVN Command I would like to save some time in my workflow by knowing what the letters stand for and grabbing the right handle right away. The “N” stands for normal, thats what I got out of the manual. But what about the UV?
Each point on a Nurbs-Surface is described by 2 parameters U,V
Therefore it is kind of a local (but not orthogonal) coordinate System along / on the Surface…
have a look at
_extractIsoCurve (Direction U/V)
_SelU _SelV (to select an entire Control Point Row)
to “see” those directions use the
_dir Commonad
if you need it very often, you can display U V with custom Isocurve Color in the display Modes
