I unwrapped a surface in the UV Editor:
In the end I need a rectangular island, therefore I straighten the edges one by one.
All edges are not straight.
The helps tells me they should:
2024-08-07_UV1.3dm (316.8 KB)
Thanks for pointing that out. It’s true, they are made straighter but not collinear. I think that help page needs to be corrected. Also the text about Smooth command is probably a wish rather than reality.
RH-83260 UV Editor straightening help wrong
You can draw lines for the sides and use curve constraints. They will give you more precise colinearity.
Thanks, logged it: RH-83311 UV Editor: edge straightening prompt and behavior inconsistent
This is still in German, in English it’s not about a closed curve.
Thanks & fixed for the next build.
