Hi, I’m developing a web service on AWS using rhino compute based application.
What I want to achieve is scaling out AWS instances, and each instances have Rhino WIP installed.
Until now, I purchased Rhino license for each instances and using it for each Rhino WIP application installed in each instances.
But lately, I read about scaling on AWS with one license.
Does this instruction mean that I can use single license for multiple AWS instances(with Rhino WIP installed) if I follow above link instruction? In this way, can multiple Rhino apps run simultaneously with one license key?
I’m not sure if I understood correctly. Please answer. Thanks.
When Rhino is logged in to a service account and is running on a Windows Server-based operating system, you will be billed $0.10 per core per hour that Rhino is running (pro-rated per minute).
This means that if you have Rhino running for 1 hour on a 32-core machine, you’ll be billed $1.60.
Billing is based on uptime, not on usage - we don’t track the activity of each core, just that you have one running with Rhino. You can scale your workloads up and down to optimize performance and cost to you.
Edit Oct 23,2019: We’re now considering removing the perpetual licensing model for server-based licenses.
Edit Sept 3, 2020: Perpetual licensing will not be available for server-based licenses.
Single computer licensing not supported on Windows Server
When running on Windows Server, it will not be possible to enter a license key to run as a single-computer license, as Rhino requires a license per core. That feature is only supported via core-hour billing, as described above.
Core-hour billing is not available for desktop clients. Desktop computers that try to login to a core-hour billing team will not get a license to run. We don’t have plans for subscription licensing for human users.
@brian Thanks for reply!
I’ll look forward to using Core-Hour Billing.
Could you tell me when it will be available, roughly at least?
Because I really need this license pricing option for the stability of my service.
Hi Brian,
Is it possible to set core hour billing with an educational license?
I wnat to try Rhino Compute, but is not possible to create a team with this type of license aparently.
Do i need to upgrade my license to use rhino compute? How do I do that?
Thanks!
Eduardo C.
UPDATE: Nervermind, figured it out. The option appears in the single license, outside the team management.
