Using "RhinoDoc doc" as argument of a function using a
Need help
I’m trying to do the following .
1- I wrote a dummy method using “RhinoDoc doc” as a parameter.
Here is the code:
public static void test(RhinoDoc doc)
RhinoApp.WriteLine(“Thread1”);
2-Then I created a separate thread in the plugin to run the method in parallel, but nothing happen ( no error … but no result! ).
Here is the code:
using System.Threading;
Thread thread1 = new Thread(()=>Process.test(doc));
thread1.Start();
Can you Help?
Hi @Johnny_Boivin,
For what it’s worth, the Rhino document is not thread safe.
What are you trying to do and why?
– Dale
Thanks for your fast response. I’m working on a naval architecture plugin where I have to make 37 copies of a base hull and rotate them by increment of 5 degree to calculate the portion of the hull that will be underwater at different heeling degrees( from 0 to 180 degree = 37 cases ) I already wrote the plugin without using multithreading and it works perfectly well but its a little slow. So for example ,instead on running one big loop like for(int hullIdx=0;hullIdx<38;hullIdx++) {RunStudy[hullIdx, doc ]}. I thought that i can split it into smaller loop and run it on different threads. This is what I’m trying to do .
Hello Dale, I found a solution. The threading code should not reside in the “protected override Result RunCommand(RhinoDoc doc, RunMode mode)” of the XCommand class but should happen in a method residing in another class outside the plugin
