Rhino mac threading multiple documents
I tried to handle multiple documents issues on mac in a method called by a background thread:
def create_results(results, callback_data, msg=None):
    parent_layer = callback_data["parent_layer"]
    rs.AddLayer(parent_layer)
    docId = callback_data["docId"]
    old_doc = scriptcontext.doc
    scriptcontext.doc = scriptcontext.doc.FromId(docId)
    except Exception as e:
        print(e)
        print("error happened in create_results")
    finally:
        scriptcontext.doc = old_doc
but somehow the results are still created sometimes in the wrong document. Do I need to use RhinoCommon to create the geometries or is there a way to use rhinoscriptsyntax
Hi @bar,
You should be able to use RhinoScriptSyntax as it get the required document from the scriptcontext.
For example, here is the source code to rhinoscriptsyntax.AddLayer.
I will add that Rhino documents are not thread safe.
When retrieving documents, I prefer to use RhinoDoc.FromRuntimeSerialNumber. You should validagte the return value too.
– Dale
