Hi guys,
How can I use Rhino curves in RIR Python environment? I want to create something out of Rhino curves using Revit API. How can I convert Rhino curves to Revit compatible curves through RhinoInside.Revit library?
An example would be great. Thanks.
kike
(Kike Garcia)
August 18, 2021, 3:19pm
2
We need to create some documentation for this, but here a sample.
RiR-ConvertGeometry.gh (13.3 KB)
Please remember to adjust Type Hint on inputs from the context menu.
import clr
clr.AddReference("RevitAPI")
clr.AddReference("RhinoInside.Revit")
import RhinoInside
clr.ImportExtensions(RhinoInside.Revit.Convert.Geometry)
if _point is not None:
point_ = _point.ToXYZ()
if _curve is not None:
curve_ = _curve.ToCurve()
if _box is not None:
box_ = _box.ToBoundingBoxXYZ()
if _brep is not None:
solid_ = _brep.ToSolid()
Yes, documentation is definitely needed. I have tried ToCurve() method but got the following error.
Solution exception:‘NoneType’ object has no attribute ‘ToCurve’
Any idea why?
import clr
clr.AddReference('System.Core')
clr.AddReference('RhinoInside.Revit')
clr.AddReference('RevitAPI')
clr.AddReference('RevitAPIUI')
clr.AddReference("System")
from System import Enum
from System.Collections.Generic import List
import Rhino
import RhinoInside
import Grasshopper
from Grasshopper.Kernel import GH_RuntimeMessageLevel as RML
from RhinoInside.Revit import Revit, Convert
from Autodesk.Revit import DB
# access the active document object
doc = Revit.ActiveDBDocument
def show_warning(msg):
ghenv.Component.AddRuntimeMessage(RML.Warning, msg)
def show_error(msg):
ghenv.Component.AddRuntimeMessage(RML.Error, msg)
def show_remark(msg):
ghenv.Component.AddRuntimeMessage(RML.Remark, msg)
curves = List[DB.Curve]()
curves.Add(Curve.ToCurve())
clc = DB.CurveLoop.Create(curves)
#Create and Start Transaction
t = DB.Transaction(doc, "Create Ceiling")
t.Start()
try:
ceiling = DB.Ceiling.Create(doc, curves, Type.Id, Level.Id)
t.Commit()
except Exception as txn_err:
show_error(str(txn_err))
t.RollBack()
I am trying to create a ceiling from a given single curve outline. I am quite new in Revit API. If I have any noob mistakes, just forgive
I got the same error from the definition you shared.
Japhy
(Japhy)
August 18, 2021, 9:33pm
4
where is the Curve in curves.Add(Curve.ToCurve()) object coming from?
It is the curve input in the Python node. I got the same error in the definition that kike shared though.
kike
(Kike Garcia)
August 19, 2021, 7:21am
6
Hi @mucahitbgoker ,
I edited the previous post to check if the user has something plugged in the component.
Now it should not show any error even if you don’t connect anything.
Hi @kike ,
I get the following error.
Solution exception:Failed to convert non G1 continuous curve.
I connected a simple rectangle as an input in your definition.
When I tried it with my script, I get this error too:
kike
(Kike Garcia)
August 19, 2021, 8:26am
8
I see,
You are trying to convert a boundary to create the ceiling.
Since Revit curves should be C2 you can not convert a curve with kinks to a Revit Curve.
On these cases you should use ToCurveLoop or ToCurveArray depending on where you like to use the result.
Celing.Create takes a CurveLoop.
https://apidocs.co/apps/revit/2022/63030aa3-d58d-b830-db18-0882c5990507.htm
So you need ToCurveLoop here to convert each loop.
Thanks @kike . Now I can use curves to create ceiling. Can I achieve element binding in Python component though? Whenever a change happens in the Grasshopper environment, it recreates a ceiling.
kike
(Kike Garcia)
August 19, 2021, 8:39am
10
Right now there is no API for Element Tracking.
We want to be sure this implementation works for the users before release it to a wider audience.
But will be available on an upcoming release.
Okidoki @kike . Thank you!
kike
(Kike Garcia)
August 19, 2021, 8:45am
12
About documentation you may use the source code itself.
Here you have conversion from Rhino to Revit.
rhino.inside-revit/GeometryEncoder.cs
And here from Revit to Rhino.
rhino.inside-revit/GeometryDecoder.cs
Searching “public static” should give you an idea of what is available.
@kike-asuni Any example for c# that you can share please?
