Are there functions on converting Revit geometry (e.g. points, curves, surface) into Rhino?
Here is the documentation on getting started with python and revit. There is a gourmet conversion in the sample: Rhino.InsideĀ®.Revit
@eirannejad may need to help as the component and python 3 are default and the syntax for the clr method may be different.
Python 3 in Rhino does have the clr.AddReference method so all those examples should work without issues.
