Using evaluate component without error in 'draw full names' mode
How can I use evaluate component without giving error in ‘display full names’ mode?
I attached range component with default values and I get error while using full names.
Here’s ‘draw full names’ mode is switched on
Here’s ‘draw full names’ mode is switched off.
Hello archz2,
you just have to rename the inputs of the Evaluate Component to “x” and “y”.
The “Draw full names” changes the inputs.
By right-clicking at the inputs, you can rename them.
The “expression” -component behaves similiar.
greetings,
Bumaye
Same issue, but not addressed yet.
Edit: Above mentioned option works I have seen many suggestion this same method, but what is the reason for this error.
Cheers,
BVR
Thanks. This trick works. Though I have to disconnect and reconnect my expression to get it working.
