Is there a way to call functions from Autodesk.Revit.DB namespace using the C# nodes? That way we can call the Revit API from the comfort of Grasshopper to do additional functions (such as assigning mass floors to masses etc)
scottd
(Scott Davidson)
December 10, 2019, 3:37pm
2
We currently only have the Python technique documented:
# Writing Python in Grasshopper in Revit
This guide is about writing a custom Python component in Grasshopper while running Rhino.inside Revit.
This grasshopper definition is available as a [download here as ghpython-revit.gh...](samples\ghpython-revit.gh)
##<img src="images/Python.png" width="35px"> GH Python component
The GHPython component contains the inputs, outputs and a code editor. To get started with the component go to the Math tab in Grasshopper and drag out the Python component.
<img src="images/ghpython-component-detail.png" width="100%" align="center">
For a detail guide on the GHPython component in Grasshopper, please review [Your First Python Script in Grasshopper Guide](https://developer.rhino3d.com/guides/rhinopython/your-first-python-script-in-grasshopper/)
Double-click on the component to open the Python editor:
This file has been truncated. show original
The C# is a little different and we would like to streamline the process for C# components. Although I do not expect the change for a few weeks at least.
fraguada
(Luis Fraguada)
December 10, 2019, 8:40pm
3
As @scottd mentioned, we don’t have too many examples documented. One of the original samples creates a TopographySurface
from points. Here is the definition: https://github.com/mcneel/rhino.inside-revit/blob/master/src/RhinoInside.Revit/Samples/Sample3.ghx
and here is the code it calls:
<item name="AdditionalSource" type_name="gh_string" type_code="10"> ElementId topographySurfaceId = ElementId.InvalidElementId;
void UpdateTopographySurface(Document doc, IList<XYZ> points)
// Delete previous surface if exists
try { doc.Delete(topographySurfaceId); }
catch (Autodesk.Revit.Exceptions.ArgumentException) {}
// Create a new TopographySurface
topographySurfaceId = TopographySurface.Create(doc, points).Id;
}</item>
<item name="CustomUsing" type_name="gh_bool" type_code="1">true</item>
<item name="Description" type_name="gh_string" type_code="10">A C#.NET scriptable component</item>
<item name="EditorPosition" type_name="gh_drawing_point" type_code="30">
<X>4</X>
<Y>66</Y>
</item>
<item name="InstanceGuid" type_name="gh_guid" type_code="9">884cfbe3-a9ab-41f5-92a5-28371cb35f74</item>
<item name="Name" type_name="gh_string" type_code="10">C# Script</item>
<item name="NickName" type_name="gh_string" type_code="10">TopographySurface</item>
<item name="OutParameter" type_name="gh_bool" type_code="1">true</item>
