Thank you for your help, but I may not have explain what I needed in a clear way. What I need is, on a vector black and white image, I need the circle in the dark area to be closer together and in the light area to be spread out more. Like this image but not lines, but circles. I need to do this on a metal sheet with the holes laser cut. I don’t need colours,
I hope my English has explain this as best as I can.
Marcel
Take a look at the Isopod plugin.
- Import the image with Params > Input > Import Image
- Convert it to an Isopod field Isopod > Fields > FieldFromMeshColor
- Get the values to influence for example the thickness of your lines with Isopod > Util > ValueAt
Dotted imagegh.gh (135.2 KB)
This topic might also be helpful to you.
Thanks . I also managed this:
Marilyn in Circles.gh (20.6 KB)
Is ISOPOD plugin on Food for Rhino?
Hi Marcel -
Isopod can be installed from the PackageManager in Rhino.
Thank you Wim
Hi Corax
I have plugged in ISOPOD, I tried to follow your example but the missing connections like domain and field from mesh i don’t understand. If you could put the connections, I would be grateful.
Thanks
Marcel
Im not sure if I understand your question, but here is a more annotated version. Please let me know if you need more details
Dotted image V2.gh (76.4 KB)
Edit: If you double-click on the MeshtoField component, you can see the C# source.
Also, you might want to crank up the resultion of the image by changing “101” to say “1001” or higher.
I have trouble finding this element.
It’s called a “relay”. These posts might help:
https://discourse.mcneel.com/t/what-is-a-relay/87095
https://discourse.mcneel.com/t/relay-component-explanation/96829/12
Thank you. Very helpful indeed.
