User Text Point Coordinate inside the Block
  1. I would like to make a Block with text that would display the Point Coordinate value of a Point included in this Block. Right now, as you can see in the video, as soon as I exit the Block Edit text stops updating itself. Is it an expected limitation or should it work? I know that this would make every Block Instance unique, but I can make block instances display different BlockAttributeText so it’s a bit similar.
Text value stops updating itself as soon as I exit Block Edit mode
  1. Similar, but more complex wish:
    I want a Block Instance with text inside that will display the height difference between the point in the Block and the external point (e.g. centroid of a surface) somewhere outside of the block. Math is allowed to calculate values but such referencing doesn’t seem to be allowed.
Hi Jakub -
We have this request on the list: RH-68819 TextField: BlockInsertionCoordinate text field
You’ll need some form of script to do this in the foreseeable future.
RH-68819 is fixed in Rhino WIP
