the command useExtrusion doesn’t work extruding some primitives, neither surfaces created from planar curves. I always use polysurfaces with isocurves visible to easily pick them in wireframe mode.
Forcing the isocurve checkbox to “on” (show surface isocurve) has no effect on objects created with isocurves off.
In Rhino 7 useExtrusion works as it should.
Not sure if this is what you are seeing, but there is a new setting in the WIP to not show isocurves on planar surfaces…
Wow!
Thank you very much!
