Use trigger component to move slider
Is it possible to use the trigger component to move a slider by 1.00 every 1 second, from 0 to 100? I cannot find a clear example of this being used.
Maybe a script component works better , here is a example python code :
import time
def print_range_with_delay(start, end):
for number in range(start, end + 1):
print(number)
time.sleep(1)
Example usage: print numbers from 1 to 5 with a 1-second delay
print_range_with_delay(1, 5)
If you want to use it in grasshopper , you can give start and end from number sliders or …
I guess I’m a little surprised that there doesn’t seem to be an easy way to do this without making a custom script.
If the time is not so relevant, you may also right click the slider and use the animate option.
You might use/modify one of these solutions:
This is how I figured it out. No scripting needed. Set the record limit to whatever maximum value you want it to go to.
Nice solution
