Automatically Run Number Slider
Hello, I was wondering if there is a way for a slider to change when a value from a value list component somewhere else in the script is changed? Specifically, I want the slider to run from 0-9 when the value from the value list is changed. I have seen a couple of examples in the forum although they work quite differently.
Thank you in advance.
example.gh (69.4 KB)
“trigger” component does the job
If you mean everytime the slider animated from 0 to 9 why you use different list item?
or every list item used to change a domain for example 0 to 3 than 3 to 6 …?
You can use smooth numbers
count.gh (4.6 KB)
It is unclear to me why would you want that. You can just remap numbers
You could script the slider to increment. This example should get you going (I see you know GHPython):
You could also write a counter like this one. Which might be simpler:
Thank you Anders for your help!
The second option was closer to what I was looking for. I have also combined that with one of your scripts (How to detect an update/change of a number? - #4 by kaspar-ehrhardt) that I found in the forum and now it works perfectly!
Again thank you for your effort and your time!
example.gh (74.2 KB)
