I’ve been using the Pancake Plugin to import a SVG path.
However, the geometry isn’t centred within the frame - Do you know how I could change this directly into Grasshopper ? (In the svg file, the origin of the drawing is the upper left corner)
You should internalize your SVG data into the Grashopper definition before sharing. I can open your definition but I can’t open the SVG file this definition it is pointing to.
