hi everyone
how ?use plug-in command Api in c#
in python is practical work
import ghpythonlib.components as gh
from Rhino.Geometry import *
a=gh.Pufferfish.UnsplitExtrudeSurface(c,v)
b=gh.Pufferfish.SplitKinkySurface(a)[0]
in C#???
For example, I want to use the SplitKinkySurface command from the pufferfish plugin in C # how?
@Michael_Pryor
@Mahdiyar
use plugin.gh (6.0 KB)
Hi
try this:
using rd = Rhino.NodeInCode;
var com = rd.Components.FindComponent("Pufferfish.UnsplitExtrudeSurface");
object[] args = new object[]{P,D};
string[] warnings;
if(com != null)
var results = com.Evaluate(args, false, out warnings);
A = results[0];
use Plugin.gh (7.6 KB)
Thank you @603419608 Your solution was great. I tried to define Component Extrude as a Custum Addition Code, so that I do not have to repeat this sophisticated operation in Code every time, but Error did you know where is the bug of this Code?
private void RunScript(GeometryBase @Base, Vector3d Direction, ref object Extrusion)
Extrusion=ext(Base,Direction);
// <Custom additional code>
dynamic ext(GeometryBase B, Vector3d D)
{var com = rd.Components.FindComponent("Extrude");
object[] args = new object[]{B,D};
string[] warnings;
if(com != null)
var results = com.Evaluate(args, true, out warnings);
var Extr = results[0];
return Extr;
use Components.gh (8.7 KB)
string[] warnings;
if(com != null)
return Extr;
return null; // You have to output something when com is null.
