I’d like to report an issue and make a request regarding normal maps in .usda files exported from Rhino 9.
Version: Rhino 9 BETA (9.0.26293.12303, 2026-10-20)
■ Attached files
- BoxNormal.usda: USD file exported from Rhino
- normal.png: Normal map used in the material
- rhino_normal_settings.png: Rhino viewport and material settings
- BoxNormal_expected.usda: Reference file with the normal map connected (manually edited from BoxNormal.usda)
- usdview_BoxNormal_vs_expected.png: BoxNormal.usda and BoxNormal_expected.usda side by side in usdview
■ Steps to reproduce
- Create a box with MeshBox (X=1000, Y=2000, Z=3000 mm).
- Assign the following material:
- M_PBR_Value118: Physically Based, Base Color R=G=B=118
- Bump / Normal Map: normal.png as a Bitmap Texture (strength 30%)
- Export to .usda with these options:
- Prim Settings
- Default layer: Default
- Model name: Box
- References
- Block handling: Embedded
- Data
- Include user strings: On
- Prim Settings
■ Issue
The normal map bumps appear in Rhino’s Rendered and Raytraced viewports (see rhino_normal_settings.png).
On export, normal.png is written out, but BoxNormal.usda has no UsdUVTexture shader prim that references it, and nothing is connected to the UsdPreviewSurface inputs:normal.
As a result, the bumps don’t appear in usdview or other USD applications.
■ Request
Could materials with a normal map be exported with the map connected to the UsdPreviewSurface inputs:normal?
For reference, BoxNormal_expected.usda adds the following to the exported file, following the same structure Rhino already uses for the base color texture (including UV reading through UsdPrimvarReader_float2):
- A connection from that shader to the UsdPreviewSurface inputs:normal
In usdview, BoxNormal.usda renders as a flat surface, while BoxNormal_expected.usda shows the bumps (see usdview_BoxNormal_vs_expected.png).
If I understand the description of the normal input in the UsdPreviewSurface specification correctly, 8-bit normal maps seem to require the following UsdUVTexture settings:
- inputs:sourceColorSpace = “raw”
- inputs:scale = (2, 2, 2, 1)
- inputs:bias = (-1, -1, -1, 0)
UsdPreviewSurface doesn’t appear to have an input for normal map strength, so the sample doesn’t reflect Rhino’s 30% setting and uses the standard values (equivalent to 100%).
Thanks in advance for your help.
BoxNormal_expected.usda (3.7 KB)
BoxNormal.usda (2.7 KB)
