Hello, i have to get a drawing of a 3d model in front view with Rhino or Vray
how to get this ?
exemple :
thanks
how to get this ?
exemple :
thanks
Hi - for an image like that, you could probably use the Technical
display mode or use Make2D
thanks for reply.
how to get a clear white background ? thanks
Is your display background color set to white?—-Mark
Hi @emile_francois
If you want to use V-Ray you should take a look at https://docs.chaosgroup.com/display/VNFR/Toon+Material
Here there’s a discussion about this explaining how to get it.
Hello, thanks for you answer.
the sedonc link (mcneel forum) is private or doesnt exist. could you post a screenshot of the content please ?
thanks a lot
I edited the link, it should work.
If not, you can use search and look for “Is it possible to achieve Outline render using V-ray?”
Good luck!
link is workin thanks
i try to use technical view, it is ok but my objet still be white. how to change it in black ? can’t find in the setting
Hi -
Can you please post a 3dm file and a screenshot of what you are seeing?
