Upload Fail (No Parameter)
I have revised a GH definition that used to upload fine, and when I upload the new version, I have the following issues:
  • there are no parameters appearing on ShapeDiver, none at all
  • there is a model, but with dimensions and settings that are different from that of the model as saved on GH
I have not changed the params much on GH so I assume the problem comes from an old plugin that I haven’t been able to update.
Screenshot 2024-08-14 at 10.59.00 AM
The white component is not related to anything anymore, but probably it interfers with the definition and may explain the issue. How to delete it? Or do you have any other idea how to fix the problem?
Thanks.
Update: I have managed to delete the white placeholders, still same result: model is outdated, no parameter appears.
Screenshot 2024-08-14 at 2.13.17 PM
I am getting now this message when uploading the product. Should help understand what’s wrong. Thanks.
Could you link to a model or include a definition that causes the issue you are mentioning?
It is difficult to guess what the problem could be, but it looks like a potential connectivity issue, or a caching issue. Try emptying your browser’s cache and make sure the connection you are using does not currently encounter issues.
Thanks Mathieu, I tried with a different browser and it worked perfectly indeed. I’ll just empty my cache. Cheers.
