Update Bugs
@BrianJ the latest RC update from 8.02.2022 messed up Rhino. Is there a way to roll back? Until now I am seeing the following errors:
  • Grasshopper startup
Priority: GhpyLoader
  Method not found: 'Microsoft.Scripting.Hosting.ScriptRuntimeSetup IronPython.Hosting.Python.CreateRuntimeSetup(System.Collections.Generic.IDictionary`2<System.String,System.Object>)'.
  MissingMethodException
  • EditPythonScript: Unknown Command
  • VisualArq objects failing (might be unrelated)
SystemInfo:
Rhino 7 SR16 2022-2-8 (Rhino 7, 7.16.22039.15001, Git hash:master @ 03d9447136d66e554d335bfc7e790f06e19f7485)
License type: Educational, build 2022-02-08
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display and OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-3-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 7\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\silvano\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\silvano\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22039.15001
C:\Program Files\Rhino 7\Plug-ins\Calc.rhp “Calc”
Hello- can you try repairing the installation?
(and re-boot)
@pascal Thanks. I repaired and restarted. Unfortunately no change. I am still on the same version.
@pascal I started Rhino in safe mode. Then _EditPythonScript → Load IronPython Yes → Gives the following error:
Command: EditPythonScript
Error occurred loading plug-in
Details:
Method not found: ‘Microsoft.Scripting.Hosting.ScriptRuntimeSetup IronPython.Hosting.Python.CreateRuntimeSetup(System.Collections.Generic.IDictionary`2<System.String,System.Object>)’.
RhinoPythonHost
at RhinoPython.Host.get_Engine()
at RhinoDLR_Python.IronPythonPlugIn.OnLoad(String& message) in D:\BuildAgent\work\commercial\src4\rhino4\Plug-ins\ironpython\plugin\IronPythonPlugIn.cs:line 119
at Rhino.PlugIns.PlugIn.InternalOnLoad(Int32 pluginSerialNumber)
I see - to go back, you can find older installers here:
C:\ProgramData\McNeel\McNeelUpdate\DownloadCache
though you may need to hunt around for the right one.
Uninstall Rhino and then run the installer for the version you want assuming you can find it - let me know if not. But you should be able to run the latest, of course, I’lll see what I can find out.
@silvano - confirmed, the RC does indeed have this bug - best to go back to 7.15 which is now the official release.
Hi Everyone,
Thanks for reporting the issue, I’ve logged it as RH-67409 to get that fixed up!
Thanks everybody for the help and for prioritizing this one.
Regarding my initial post’s mentioning of VisualArq objects stopping to work, I can confirm it is related. The objects that stopped working, are Grasshopper based object styles. I assume since GH is starting with errors, those objects cannot get their geometry from GH.
Version 7.15.22039.13001: OK
Version 7.16.22039.15001: Above bug is present
After a bit of investigation, I found that I can reproduce this when IronPython 2.7.11 is installed separately to the GAC, so uninstalling (or unchecking the GAC check box on its installer) may help in the meantime.
@curtisw Thanks for investigating this. Uninstalling IronPython from the GAC solved the problem for me.
@silvano Awesome, glad to know that works for you. A fix is coming that will not require you to do that in the future.
RH-67409 is fixed in Rhino 7 Service Release 16
