Update all block instances in real time, while editing?
Greetings,
Can all instances of a block update in real time, while editing one instance? (before closing BlockEdit)
Or is there any way to create clones of geometry that update while the user is editing one instance or another?
It will be a great improvement for blocks…
Thank you!
PS, this already happens with Reflect SubD Object, but instead of a mirror it should also work when the SubD (or the geometry) is just copied.
Hi @Bogdan_Chipara,
Currently that is not possible.
The consideration is for performance and in a large file this has potential of slowing down the Rhino display.
This feature request has been logged as RH-85384/Update-Display-of-All-Block-Instances-While-Editing
It will be considered by the developers for future versions of Rhino.
Thank you,
Mary Ann Fugier
@mary , thanks for your reply.
It should be exactly like the Reflect SubD object or copy with history
