Today I tried to adjust the mapping of two sub block, but always if I leave one object and go to the next one, the changes are lost. Finally I found the time consuming workaround - I need to press “OK” and to leave the BlockEdit mode between the editing of the sub blocks.
Hi Micha, thanks, I’ll check.
Hi @pascal, could you please check this issue too:
It is very annoying. The display of the scene during the editing of blocks has become worse and worse over the years, with each release taking a step backwards. In the past, the surrounding scene in the foreground was hidden, now not even the edited object is hidden.
