Unpredicted clipping edges in V8
Hi All.
I have such strange double edges while clipping of a single surface with a hole. (V7 has no such issue)
Untrimming the hole solves the issue.
111.3dm (5.4 MB)
One more thing.
If an object has a Name, I was not able to select the name (highlight it with mouse or keyboard) in Properties dialog and delete it by Del keyboard button.
Deleting with BackSpace works.
Hello- I see that, thanks.
RH-75573 ClippingPlane: doubled edge
The same problem here. Rather confusing stuff.
Rhino Wnetrze Test.3dm (4.8 MB)
System Info
Rhino 8 SR18 2025-3-11 (Rhino 8, 8.18.25070.14001, Git hash:master @ d450d6adb914b46ae47a91e60cd335723789cf13)
License type: Educational, build 2025-03-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.10
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 12-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.50
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 12-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.50
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 8-19-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-11-2024
Driver Version: 31.0.15.5350
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.5.1.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.6.2.0\bella_rhino.rhp “Bella” 24.6.2.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BrickDesign (6e4f525d-d830-4e65-86af-b3719fcc4159)\1.2.0.0\BrickDesign\Common\BrickDesign.rhp “BrickDesign” 1.2.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Crash\1.4.2-beta\Crash.rhp “Crash” 1.4.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Karamba3D\3.1.50129\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.18.25070.14001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.18.25070.14001
unclipped block instance - looks ok
clipped block instance - section surface is bigger than it should be
clipped block instance in edit mode
The same happens in the fron view, so it makes it impossible to create a proper section view of this slab.
Hi Jakub -
The thickness of that slab layer is 0.5 units and your document tolerance is 0.1 units. You should always make sure that the tolerance is at least one order of magnitude tighter than the smallest feature in your scene. Changing the tolerance and refreshing the view clears this up here:
This was just a test file so I didn’t pay much attention to tolerances, especially in the context of Clipping Planes. Rookie mistake on my side. Thanks Wim.
