I have a problem with using clipping planes for details. Whenever i try to create a cut through detail using clipping planes of a curved surface I get an incomplete edge. This happens with and withoud a custom depth. See figures below. I’d like to not have to add intersect lines every time a want to create a cut through detail.
This is the view in the perspective viewport, you can already see missing lines at the edges.
Primary display: Microsoft Remote Display Adapter (Microsoft) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Remote Desktop display device with 16 connection(s)
- Windows Main Display using connection #0
- Secondary monitor using connection #1
Primary OpenGL: NVIDIA Quadro P2000 (NVidia) Memory: 5GB, Driver date: 6-4-2018 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 391.74
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
Secondary graphics devices.
Citrix Indirect Display Adapter (Citrix Systems Inc.) Memory: 0MB, Driver date: 1-23-2019 (M-D-Y).
> External USB display device with 0 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-4-2018
Driver Version: 23.21.13.9174
Z-Buffer depth: 24 bits
Total Video Memory: 5 GB
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
Your GPU driver is 6 years old. The latest for your GPU is at the moment Driver Details | NVIDIA . When you install the new driver make sure to go for the custom/advanced install type and check the Clean Installation checkbox.
