Unknown Commands showing up for _Extendsrf and more
I’m working in the latest Release of V8 for Windows and So far Extendsrf and _Untrimall result in Unknown command.
I installed the latest release candidate and it also has the same issue.
@Isaiah_Coberly these are part of SolidTools plugin (that ships with Rhino). I suspect that for some reason this plugin is deactivated.
if you run _PluginManager and type in search SolidTools, do you get to see this?
It should show enabled
Hey That worked! Thank you so much. I have no idea how that became disabled.
