Unknown command _Isolate
V5
grey bulb with half black half yellow square
used for selecting the opposite of a selection and hiding it.
select some lines, click it and nothing happens.
says unknown command _Isolate.
well its worked thousands of times this last 10 years or more.
whats going on
Steve
that’s most likely related to your other post, where you say you tried restoring the Rhino 5 toolbars with Rhino 7 toolbars
Isolate was not in Rhino 5
In Rhino 5, that icon has:
! _Invert _Hide
Are you saying by using Rhino7 to replace my missing custom toolbuttons, its broken my tool I make great use of, has to be one of my 5 most used tool each day.
its somehow replaced it with _Isolate rather than what it should be
! _Invert _Hide
I also am missing many tooltips.
All in all has Rhino 7 , supposedly compatible with Rhino 5, broken my tools now ?
Now what do I do ?
Steve
Shift right click the button to edit and replace isolate with the macro I just posted.
will do,
the right click says
! _Unisolate
Whats the correct code for that ?
I also altered the Text to Invert Hide as it said Isolate.
was this button given a revamp in 7 and its coding changed then ?
Is there a chance others have been messed up ?
is there a list of those I need to revisit and edit ?
my tooltips have disappeared in places, see other post. That one had lost its tooltips, so would it be that others missing tooltips also need fixing,?
I have a sinking feeling here.
Steve
Hi, please what is the correct code for the right click option. which unhides the inverted.
I have changed the left click to
! _Invert _Hide
Steve
For Rhino 5 that is ! _Show
Hi, for the right click on that invert button would that be just ! _Show or ! _Invert_Show ?
Steve
Like I said, for Rhino 5 the right click is Show
