I’ve been battling some dimension issues, specifically anywhere between 1/32" to 3/32" and now I’ve found this discrepancy.
Note that I pulled the dimension string (on right) by typing in 10’-0".
Hello- please post a file with that object and the dimension, and I’ll see if I can tell what is going on.
Thanks, @pascal. Could you remind me of the email to use if I can’t post it publicly? Thx
Hello - send to tech@mcneel.com - all we need is the object and the dimension, not the whole project.
Was able to recreate with a simple square. Thx
DimensionAccuracy_AlanFarkas_211118.3dm (144.8 KB)
Any movement on this as of yet? (Not pushing, just checking in )
Hm, maybe I do not understand the problem yet- I see a sqare that is 1.25 units in both directions - the dimensions and the BoxEdit info are not ad odds with that as far as I can see… what should I be looking for?
Ah. Yes, well you saw what it did on my end-
Sorry, had to bail on my comment…So, on my end it shows the BoxEdit diff than the dimension string
Anything to be done to fix this. It’s been a real problem.
Thx as always
