Getting 1/64" difference in- and outside Block
Ok, so here’s something that’s wasted a ton of my time until I just figured out this happens. I have my Units set to 128th of an inch. Select the block and you see 7’-4 1/64" in the Box Edit window.
Click inside the Block, and BoxEdit says the geometry is 7’-4"
Can someone please take a look at my settings and tell me what’s going on? It’s driving me nutso that my geometry isn’t lining up, and it effects the looks of my Sections, etc.
Thanks.
1-64in off Block.3dm (152.9 KB)
Hi Alan - the more precise difference in Bounding Box height is
inside BlockEdit
Length = 87.9983215 inches
Block instance:
Length = 88.0120888 inches
= 0.0137673 difference … I’ll investigate.
Hm, I guess the answer is, now that I look at it in model units (feet) and not inches, the discrepancy is just about file tolerance - .001. On the other hand it does not improve with tighter tolerance. Still poking…
https://mcneel.myjetbrains.com/youtrack/issue/RH-50976
Thanks, very much appreciated. Feeling like I’m not able to be confident in my modeling because of this
Hi Alan - keep in mind that the 64th in inches and your file is using feet as the unit, so the discrepancy is no4 1/64th of the current file unit, it is closer to 1/1000.
@Alan_Farkas - it turns out there’s a curve on an off layer in that block that is causing the discrepancy.
