"Unexpected character encountered" when trying to connect hops to python
Hi, I’m very new to coding, Python and APIs.
I’m trying to run the simple example of connecting app.py (with a pointat function) to grasshopper Hops. I installed Python 3.9 and the needed libraries, this is the code:
from flask import Flask
import ghhops_server as hs
import rhino3dm
# Register Hops app as middleware
app = Flask(__name__)
hops = hs.Hops(app)
@hops.component(
    "/pointAt",
    name="PointAt",
    description="Get point along curve",
    # icon="pointat.png"
    inputs=[
        hs.HopsCurve("Curve", "C", "Curve to evaluate"),
        hs.HopsNumber("t", "t", "Parameter on Curve to evaluate", default=0.5),
    outputs=[
        hs.HopsPoint("P", "P", "Point on curve at t"),
def pointat(curve: rhino3dm.Curve, t):
    return curve.PointAt(t)
if __name__ == "__main__":
    app.run()
After running
python .\app.py
I’m giving the Hops component the server address: http://127.0.0.1:5000/pointat, and what I’m getting is this Error:
1. Unexpected character encountered while parsing value: <. Path '', line 0, position 0.
In the PyCharm terminal what I’m seeing is:
[INFO] 127.0.0.1 - - [06/Jan/2023 17:16:28] "GET /pointat HTTP/1.1" 404 -
[INFO] 127.0.0.1 - - [06/Jan/2023 17:16:40] "GET /pointat HTTP/1.1" 404 -
I feel like I’ve been through everything I saw on the internet, I just can’t seem to get it to work.
Thanks in advance
Hey,
try changing the endpoint to /pointat in the component definition (all lowercase)
it also looks that your component is missing "outputs" = [...
Can’t believe this entire thing was one capitalized letter… Thanks a lot! Now it works
