Is this possible?
The server runs but hops component doesn’t connect with a message:
1. Unexpected character encountered while parsing value: <. Path '', line 0, position 0.
Is this possible?
it’s possible:
difficult to tell what could be wrong with your setup without looking at your code. There’s a similar issue here: Create CPython components using Hops in Grasshopper - #58 by tom_svilans
I would recommend trying to hit the url with your browser first to see if that works. You should get json data back which describes your function as a component.
I’m runnning it within PyCharm
Perhaps that’s the problem because it creates a server to run the Jupyter on port 8888 then from inside Jupyter I’m trying to run the server on port 5000 for hops.
