I’ve been looking over the custom undo event command and several of the provided examples for the method AddCusomUndoEvent. [ ie. doc.AddCustomUndoEvent(“Name”,Handler method); ]
I’ve been trying to understand this method in order to use it to count the number of undos and redos commanded by a user. I’m using these counts to coordinate specific data in a custom plugin with rhino and I’m writing because it appears that the provided method seems to require a command to enable it rather than just refer to the event itself - an event would be much more helpful.
My questions are:
- Is there an event that I can subscribe to instead of using the above method?
- If there is an event is there another event for ‘redo’?
I do hope events are available. I see other similar events but nothing strictly for undo / redo.
