I have created a custom CustomUndoEventArgs Event inside of a command in my Rhino Plugin. The Undo event works fine and I’ve seen in the comment below that the Undo event is also called on Redo. However. My command doesn’t seem to allow for a Redo after Undo is called. My command, as well as my Commands Undo only modifies the UserDictionary of a RhinoObjects Curve Geometry. Do I need to modify the document to qualify for a Redo?
Here is some code, its stripped back and rename, but its the same basic thing.
using System;
using Rhino.Commands;
using Rhino;
namespace myplugin.mycommands
// A custom command in my Plugin
public class MyCommand : SuperSpecialCommand
static MyCommand _instance;
public MyCommand()
_instance = this;
AllowUndoCreate = true;
public static MyCommand Instance => _instance;
protected override Result RunSuperSpecialCommand(RhinoDoc doc, RunMode mode,
SuperSpecialPlugIn plugin)
// Add data to a UserDictionary object.
return Result.Success;
// A wrapper class in the plugin that handles things for every command.
public abstract class SuperSpecialCommand : Command
internal bool AllowUndoCreate { get; set; } = false;
Result runcommand = RunSuperSpecialCommand(doc, mode, plugin);
if (AllowUndoCreate)
doc.AddCustomUndoEvent($@"Undo {EnglishName}", OnUndoObjectCreate);
return runcommand;
protected abstract Result RunSuperSpecialCommand(RhinoDoc doc, RunMode mode,
SuperSpecialPlugIn plugin);
private void OnUndoObjectCreate(object sender, Rhino.Commands.CustomUndoEventArgs e)
var objs = e.Document.Objects.AllObjectsSince(e.UndoSerialNumber);
foreach (var obj in objs)
if (obj.IsSuperSpecialObject())
// Remove all UserDictionaryData of this object.
– cs
