I am trying to do a sweep 2 rails with python, and understand it
This is what I got so far cobbling together bits from various searches here and the RhinoCommon SDK docs. Code:
import Rhino
import Rhino.Geometry as rg
import scriptcontext as sc
def Sweep2():
rail1 = rs.GetObject("Select first rail curve", rs.filter.curve)
rail_crv1 = rs.coercecurve(rail1)
if not rail_crv1: return
rail2 = rs.GetObject("Select second rail curve", rs.filter.curve)
rail_crv2 = rs.coercecurve(rail2)
if not rail_crv2: return
cross_sections = rs.GetObjects("Select cross sections", rs.filter.curve)
if not cross_sections: return
cross_sections = [rs.coercecurve(crv) for crv in cross_sections]
sweep = rg.SweepTwoRail()
sweep.AngleToleranceRadians = sc.doc.ModelAngleToleranceRadians
sweep.ClosedSweep = False
sweep.SweepTolerance = sc.doc.ModelAbsoluteTolerance
surface1 = sweep.PerformSweep(rail_crv1, rail_crv2, cross_sections)
sc.doc.Objects.AddBrep(surface1)
#sc.doc.Views.Redraw()
if __name__ == "__main__":
Sweep2()
The last error I was getting âŠ
Can someone guide me a bit? looking here & here ⊠still confused.
Thanks, «Randy
